WTD: Original Marshall JCM 800
As above, must be a vertical input original 80's JCM 800, 100 watt
Ta
Current Gear: 2006 Gibson Les Paul Classic, Charvel So Cal, 1999 Gibson SG Standard, 2008 Fender Road Worn Strat, 2008 Fender Road Worn Telecaster, Partscaster SRV-lookalike Strat, Martin D28, Gretsch Jim Dandy, Kemper Profiler and Kemper Kab, Marshall JCM800 2203 (Dan Gower modded), Marshall 1960A w/Greenbacks, Positive Grid Spark Mini, various pedals and recording gear!
  • HHwarnerHHwarner Frets: 137
    edited August 2014
    Dont be put off getting a Horizontal Input 2204 50w They didnt suffer the same cost cutting exercise as the 2203 100 w. Awesome amps and can be picked up cheaper than a vertical input 2203. Mine sounds better than my JMP 2203.
  • Had a horizontal 50 watter (1985) before, not bad but not as good as vertical 2203's, IMHO.
    +1. I currently use a 1984 2204 head. Absolutely fantastic. It has shed loads of bottom end thump. Stupidly loud though so don't ignore how useful the low input is then boost with pedals. I use a Fulltone OCD with mine which sounds wonderful.
