Thanks to all who helped restore calm yesterday. I think that should be OK once it's all sanded and polished. It should contrast nicely with the white and the natural edge and the blue top. An odd design feature, but no longer the complete feck up that I was fearing yesterday!
I wonder if it's worth tying it in with another feature elsewhere.
Ideas:
Notched walnut knobs to act as a pointer
Edge inlays on the fretboard face in the same shape
A notch at the top of the headstock., or aligned with each tuner post... then add walnut buttons
Instagram
Looks like I can make some of these. Just need to get some small alu tube and set screws to make the internals.
I'm thinking a small walnut inlay in the top of the guitar (think 2mm wide, 20mm long strip) which will lead to the closest knob, which will look as above.
I might then also inlay some 4mm walnut dots into the top of the guitar to represent the "10" position for each knob - ie when the pointer bit is at the inlaid dot, that's the "10" position.
Got some thoughts re the headstock too.
Thanks @Wez!!
Hmmmmm ...
(Ruler added for scale)
The inlay is 1.5mm thick. The channel it's sitting in is 1.7mm wide. Although there looks like there's a gap between inlay and channel, that's more because the channel is deeper than the inlay is thick, so it's recessed by about 1mm.
Just messing about and trying things out at this stage, but this has some interesting potential for future builds!
Good save, mate. I actually like the ‘feature’
I was going to suggest having a flat spot on the rounded shape like where the socket is on a tele.
