Zvex Super Hard On?
robkayrobkay Frets: 11
Anyone used one of these, any thoughts.....might build one up this week to give it a try....
  • stickyfiddlestickyfiddle Frets: 27897
    I have a home-built one on my board. It's a good, slightly gritty booster, with a shitload of gain at the top end. Definitely worth a go if you're building your own. The parts hardly cost anything!
  • DeijavooDeijavoo Frets: 3299
    I had a clone until I bust it. Awesome tool.
  • KebabkidKebabkid Frets: 3357
    edited August 2014
    I heard/tried one of these recently - older looking design. Wonderful boost that imparts this quality to your sound and the sort of pedal you can leave on. It's hard to describe what it does and I see it as a subtler version of my Xotic EP boost. Yes, it boosts and there's some added brightness too as well as body and light compression and it sounds like a pushed amp.
    I was told the draw on these was minimal.
    Simple control + simple components = very useful and nice sounding pedal
  • stonevibestonevibe Frets: 7222
    edited August 2014
    I use a Mooer sized one on my board that I bought from someone off this board recently. I owned a ZVex original and they do exactly the same thing.
    Useful pedal live and very simple.
    Guitar Bomb & Nembrini Audio Summer Giveaway
  • AdjiAdji Frets: 146
    Really great pedal, there is a reason it is one of the most cloned, simple, transparent and powerful.
    The only one that betters it for me is the Bob Burt Clean Boost, which is a monster.
    ____________________
    www.adamironside.com
    www.youtube.com/Adji87
  • robkayrobkay Frets: 11
    edited August 2014
    Great thanks all for your thoughts....
    Rob
  • I built a pedalparts clone and am quite impressed especially playing my fender bronco through it - it adds some nice sparkle to an old pickup.
  • If you leave it switched on, on the board should it be infront or the end of the pedals?
  • ICBMICBM Frets: 73238
    I will be the lone voice as usual and say I didn't like it. I found it harsh, spiky, and overly 'touchy' as a clean boost, and noisy when used to push an overdriven amp - even if you don't turn the knob, which admittedly is marked 'Crackle OK', but is horrendous at any kind of volume.
    I didn't mind the Super Duper 2 In 1 which uses the same circuit, but only when using the side with the volume control (with or without the first one).
    I feel I should add that while I like mine, I prefer my cloned Alembic Stratoblaster (pedalparts's Blaster). A bit more mid-humpy but less harsh and much better with single coils.
    See I love it because of how harsh and spiky it is. Each to their own I guess.
    True. I like harsh fuzz and distortion, just not clean boost. Actually I don't like clean boosts really :).
    I don't mind the MXR Micro-Amp and the EH LPB, but I can't think of when I'd want to use either of them.
    I think of stuff like Shellac or Retribution Gospel Choir when I use one, and the closer I sound to those guys the better.  :-D
  • BodBod Frets: 1354
    I've got a Super-duper that I built from 2 SHO PCBs from Pedalparts.  I keep the first half switched on permanently, which adds a real spark to the sound IMO.  The second half I use purely as a clean boost with the master on unity and then the gain at 10 o'clock.  Works a treat and it's a great utility pedal.
  • EdGripEdGrip Frets: 736
    I have built a couple of these. I like what they do, but I find they do it a bit too much. I'm told that if you bring their input impedance down a bit (I think it's 10M as standard) it gets a bit less bright and a bit less noisy, but still does its thing. I haven't got round to trying it - good candidate for a breadboard!
  • photekphotek Frets: 1471
    Ahhh Shellac. It has been a while, off to find At Action Park now!
  • I only recently sold mine. I'd had it a good few years and it was my favourite pedal. I used it all the time.
    I'm using a pedal parts lpb kit now. I'm building one of his super super clones at the moment.
