Power tools will generally take off at least 3 smidges before you've realised, and you won't get a nice straight edge with a Dremel and sanding drums.
Sandpaper with a flat block. And take it evenly off both sides of the pocket / neck.
Personally i would do it on the body with template and router. The dremel and sanding drums would not be used for this jpb
Instagram
I would widen the neck pocket - it may be more difficult but it's the technically correct option. Sandpaper glued to a hardwood block and rubbed along the sides of the pocket *only* parallel to the body, not up and down, should do it if it's only a smidge that needs to come off. It can be tricky to get far enough into the corners though.
Make sure the block is wide enough to sit firmly on the floor of the pocket as you move it, so it keeps the side walls vertical.
