There’s a small possibility there’s some sort of bad resonance in the guitar itself too, even though it doesn’t seem note-specific if it does it up the whole length of the string.
Could the adjuster screw be slightly bent? You could try turning it to see if the saddle rocks as you turn.
Series LP Junior and what a difference like night and day. I got mine from Glued to Music on line. Hope this helps.
I’ve had a lot of core and S2’s plus SE’s in the past and this wide fat neck profile is really beginning to feel like home.
