Snakehead Tele, refinished
  • paulnb57paulnb57 Frets: 3222
    Corvus said:
    ^^ looks great with the ashtray on.
    The neck's now done and packed for post now. We're going for original style with no bushes; 1/4" tuners are a nice push-fit and we can always counterbore it later if ever needed -
    Fabulous! Thanks Bill
    Neck arrived yesterday tea time, so later it got assembled
    Nice packaging from Bill @Corvus no bubble wrap, wrapped in Jute and in a thick cardboard tube, very nice! And MrsB is going to sew something from it!….
    Neck quality is superb, everything I hoped for, nice fat but no too fat profile, sublime fretwork, if I wanted a custom build thats where I would go.
    Fitted the tuners and then marked and drilled the neck to body screw holes, stung it up and the nut is pretty much perfect, gave it a rough set up, no buzzes no fretwork needed, fabulous. Its being left to stand for a day or two to settle, then it will be set up proper.
  • TheMarlinTheMarlin Frets: 8499
    I had a Snakehead build a while back.  Stupidly sold it. Was an absolutely fabulous guitar!
  • photekphotek Frets: 1507
    Brilliant! Pop a demo up once it’s all settled in :+1:
  • Looks great Paul! I know where to go for a quality bespoke neck now ;)
  • TeyeplayerTeyeplayer Frets: 3432
    I only have to look at the curve of that neck to know it’s perfect. Looks a very comfortable handful. Great work both @paulnb57 and Bill @Corvus.
  • CorvusCorvus Frets: 3095
    Excellent, looks good that Paul, and glad it went in there without fuss :)
    And cheers @Teyeplayer :+1:
  • TTonyTTony Frets: 28444
    That’s all looking good to me.
    :+1:
    If space is too tight for the mini toggle, could you use a couple of push/push or push/pull pots instead?
    Or, could you use a couple of rocker switches, maybe on the top edge of the bridge plate?
    edited January 2023
    1
    Some good ideas Tony, I think Im going to sack the Eldred wiring (I have another Tele with it) and replace the tone with a pull pot to coil tap and remake the control plate
    The more I look at it the more I dislike the paint colour, its a bit dull and boring, so I can see it all coming apart again for some colour….
  • andy_kandy_k Frets: 834
     A relicced Bone white, with a bakelite pickguard would do that some justice.
    Also, a split coil with some sort of exaggerated tone cap works well, I did it to one of my Jeff Beck style Esquires. ( actually I did a single vol pot, with a pull to activate  wah tone, on a full size humbucker, but you have the coil split option on your vol knob )
    I like it.
  • WezVWezV Frets: 17500
    He's not wrong!
  • rze99rze99 Frets: 2504
    White all day
    edited January 2023
    Snakehead in White Satin….
    Scratchplate is not quite there, I need to make a new control plate and ditch the mini toggle, just a volume and tone….
    How about white?
    White could look good ....
    :D
  • DrBobDrBob Frets: 3043
    That is now looking absolutely stunning
    That's nice, the white suits it very well.
  • DdiggerDdigger Frets: 2522
    edited January 2023
    I took the factory tour in Corona in 2018 while visiting relatives in Longbeach.
    Here is a link to a thread from then...
    http://thefretboard.co.uk/discussion/131893/
    There was a corridor with guitars on display and here is one of them...
    https://i.imgur.com/dsBB9Au.jpg
    Wow!
    I didnt really get along with the white and ummed and ahhed before refinishing, deciding to match the colour to our new caravan…
    With the exception ot the bridge ashtray cover, all the aged hardware has been replaced and I made a new scratchlate and control plate…
  • lovestrat74lovestrat74 Frets: 2676
    Life's simple pleasures... camping and single pickup guitars :)
