You've seen this guitar before, it's been around! I bought this on a whim, despite not being a Les Paul fan I've recently been feeling like I should own one, so when this came up again I grabbed it.
It's a nice guitar and built to Graham's usual standards, the P90 actually sounds great but the guitar doesn't do much for me so I'll try something else.
When I got it the neck was slightly rough, so I have re-sanded, oiled and waxed it back to smoothness. Also set it up so the action is nice and low on a new set of NYXL 10's.
GSP Basses (Graham Pollard), custom all hand built, single cut boutique LPJ.
Specs:
Mahogany body and neck with the most amazing AAAA Quilted Maple cap and Rosewood board.
Stained and oiled finish to the cap.
Back and neck is finished with Crimson Guitar Oil.
Pickup - Oil City Jazzwatch.
Bridge - Faber Vintage Aged Wraparound.
Tuners - Faber Kluson Style.
Wiring and Pots - Six String Supplies LP Jr Wiring Kit with SSS Premium PIO.
Head stock drilled for Kluson tuners (8.8mm front 6.3mm back).
Neck has a 2 way rod.
Bone nut 43mm
Width at 12th fret: 52.5mm
Neck thickness: 1st fret - 0.897" - 12th fret - 0.944"
12" radius fingerboard
Oil City Jazzwatch pickup
Routed for one P90, a second pickup could be added as there are wire runs are under the cap.
