Red Rickenbacker 330, made in February 1992 (serial number on the Jack plate is B5 9143).
Has the original Ricky case.
I only bought this on FB last December, and much as I want to enjoy it, I’m no Paul Weller and it is not getting played nearly as much as my other electrics (of which I have too many, having gone on a bit of splurge late last year).
A terrific 31 year old guitar, but one or two dinks and some light scratches on the back (but not through to the wood).
Soecs, from the Rickenbacker website, are these:
Body Type | Semi-Acoustic | No. Frets | 24 | Scale Length | 62.9 cm (24 3/4'') | Neck Width at Nut | 41.4 mm (1.63'') | Neck Width at 12th Fret | 49.05 mm (1 .931'') | Crown Radius | 25.4 cm (10'') | Body Wood | Maple | Neck Wood | Maple | Fingerboard Wood | Rosewood | Weight | 3.6 kg (8.0 lbs.) | Overall Length | 100.3 cm (39 1/2'') |
| Overall Width | 38.1 cm (15'') | Overall Depth | 38.1 mm (1 1/2'') | Neck Binding | No | Fret Marker Style | Dot | Tailpiece | 'R' | Bridge | 6 Saddle | Neck Type | Set-in | No. of Pickups | 2 | Type of Pickups | Hi-gain | Output Type | Mono | Machine Heads | Schaller |
https://i.imgur.com/mMSQGsx.jpg
£1500
'You are an idiot, you loved that guitar' she replied correctly
If I can sell some bits I will be in touch - its hard going at the moment though !
