Is this a bonkers idea? Seven or eight-string acoustic for close tunings
Some of my favourite fingerstyle guitarists use tunings that involve unison strings and/or strings tuned only a tone apart. Think Martin Carthy, Nic Jones, Alasdair Roberts etc.
Wondering whether there would be any mileage in a seven or eight-string guitar where the extra strings are not used to extend the range, but to fill in the gaps, as it were. For instance if you had an eight-string you could tune it DGADEGAD, or CGCEGGAC, or DADEF#GBD or something like that.
Thoughts? Would it just get too complicated? Has it been done already and I just don't know about it?
  • TanninTannin Frets: 5644
    I think the first question to settle is can you happily cope with the width of a 7 or 8-string in normal tuning? It's a fair stretch, some people are comfortable with that, some are not.
    If yes, then I think it is a great idea. There are lots of voicings you can do easily enough on a piano which just don't work on guitar (assuming standard tuning). It would be a major project to (a) get the guitar, (b) get it set up the way you want, and (c) master playing it, but a very worthwhile one.
  • StuckfastStuckfast Frets: 2435
    Hmmm. I've never played a seven or eight-string guitar. I do have a pedal steel which at least gets the right hand used to playing across a wider range, I guess. Unless anyone already makes an acoustic with more than six strings it could be a bit costly!
  • Paul_CPaul_C Frets: 7922
    Hmmm, trouble is those are all either classical guitars or fan fret / multiscale jobbies which is exactly not what I'm thinking of. A brief eBay search suggests that Ukrainian guitars are often strung with seven strings. I wonder how long Evri would take to deliver from Kyiv right now.
  • ToneControlToneControl Frets: 12096
    why not try a closer-interval tuning on a 6 string first?
    People use a C6 tuning on 6 string lap steel for example, you don't need 8 strings to use smaller intervals
    There are numerous makers building 7 and 8-string acoustic guitars. (Steel string ones, I mean.) Emerald and Stoll are two that occur immediately. Many (probably most) do them with fan frets for the very good reason that no single scale length is really properly suited to notes from a low B to a standard high E. Fan frets simply make a lot more sense on a 7-string.
    Of course, in your case, that reason doesn't apply, but the fan frets will do no harm and it will always be cheaper to buy an instrument off the shelf than a custom-made one.
    Choivert said:
    I saw that, but it's not a true 7-string. It's a 6-string with a doubled course for the G string to make it sound a little like a 12-string.
    I have! That's why I'm interested in exploring the idea further.
    I should try a fan fret 7-string one of these days. I always think they are fugly as hell though. How well do they work with a capo?
    what tunings have you tried so far?
    The tunings I regularly use are:
    Open D
    DADGAD
    DADEAD
    CADFAD
    C#ADEAD
    EACEAD
    and occasionally open G
    That's about as far away as I can go from standard tuning without having to restring with different gauges, change the nut etc.
  • Stuckfast said:
    Ah man, I'm sorry I hadn't seen the second course on the G. Could you recut the nut and potentially saddle and make it a true seven? The question would be is the fretboard wide enough to play seven string comfortably.
    You could also find a wide fretboard 6 string and add a banjo tuner or two to the top of the headstock big joe style. Maybe best not done to an expensive guitar.
    That's not a bad idea, but going further, I the easiest thing to do would be to buy a cheap 12-string and replace the nut and saddle?
    Yes this makes much more sense. Since a 12 string will have a wide fretboard too. I've seen a couple of people make their 12s into 11s with a single g string. No reason you couldn't go further. The benefit of this way is if you wanted to try a 8 string, you would only need another nut and saddle since you would have tuners spare (although less fretboard space per string)
    Great thinking there. And you will have plenty of room for 7 strings if you are used to a standard 44mm nut. The standard 12-string nut is 50mm, with 48mm also common. A 50mm nut with 7 strings will have pretty much the same spacing as a 44mm nut with 6. It would be a bit squeezy for 8 but if you are one of those players who doesn't mind those dinky little 42.5mm nuts some Takamines use you'd be fine.
    Experiment with a medium-cheap 12, if it works re-fit the original nut and saddle, sell it and buy something you really like. Great plan!
    It's a plan! Thanks everyone, I wouldn't have thought of that approach by myself.
    Could be.
    Take a look at M D Phillips Cleartone conversions to see this sort of approach done without luthier skills or financial investment - he tries to make do with the parts he has to hand.
    With a new saddle and nut you could make it work, but might need more pronounced notches on the saddle to keep the string spacing even, since I assume some peg holes will be slightly off where you'd want them to be
    That's exactly the sort of inspiration I'd rather avoid...
