D string very sharp compared to other strings..
I am building/assembling a 7 string fan fret. It has a Koloss Headless bridge.
To get a correct intonation, the D3 string saddle position has to be a lot nearer to the bridge compared to the other saddles.
I'm using a Peterson Strobestomp for tuning and cross referencing with other tuners.
For intonation, I compare tuning between the 3rd and 15th frets.
I'm also using very, very light gauge strings, 20 plain gauge for D3, with a low 1.2mm action.
Any ideas what could be causing this?
Many thanks
Edit: But, it's in tune, so the intonation might be correct.
But the intonation is almost entirely dependent on the core gauge - or if anything flatter than how you would expect a plain string of that gauge to intonate - so is much flatter than the equivalent plain string, hence the '2/4' stagger of a wound-3rd set vs the '3/3' stagger with a plain 3rd. (In 6-string sets obviously!)
Does that make any sense?
