Instagram
Where I got tear out is dead on the bottom left yellow mark. I guess this requires some climb cutting, but everything I’ve read says absolutely don’t use climb cutting with a router table setup.
I’ve ordered a Triton bobbin sander. I’ll use this to smooth down the edges more before I continue routing. I’ll also try to use it to modify the curve where I tore out to clean up the shape if I can.
Thanks for the wisdom all
Taking too much off in one pass will lead to tear out no matter how well you plan the direction of cuts. Taking smaller passes or cutting closer to the outline on the saw is a good way to help reduce the chance of error.
Instagram
Special points for getting to within 0.23mm in MDF! I have a similar, now abandoned project with neck templates so I can feel first-hand how tricky that is.
started on the fretboard dots. Used a white wax pencil to mark it.
Drilled
today I’m going to try to cut the headstock down to thickness and start on the neck cutout.
thanks
