In fact, with modern glues a finger joint is just as strong as a dovetail anyway. The traditional woodworking joints were all developed when glues were weaker and really only locked already tight-fitting parts into place to stop them moving, rather than providing the main strength.
To be honest I'm not that concerned about the strength, I just thought it would look a bit nicer with dovetails while it won't be covered
Pine is soft so you can sometimes chip the edges of the dovetails when cutting them so you don't get a clean joint and might need to fill and sand any holes for a smooth finish. Once glued up though it will be perfectly strong enough. Harder woods cut cleaner.
Thanks for the advice. Yes, this is what I'm worried about with the pine being so soft. I may just buy something a bit harder and perhaps two different colours.
I remember having to make them with only hand tools in woodwork… not easy without practice. Even harder to do some of the clever cabinet-maker stuff, eg where the dovetail isn’t visible on one face, for things like drawer fronts.
https://www.ebay.co.uk/itm/385244778299?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=nkpvwaqdtv2&sssrc=2349624&ssuid=Bq_PmGF8QpG&var=653127774492&widget_ver=artemis&media=COPY
https://www.ebay.co.uk/itm/385469390194?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=oTeiDRKZSIq&sssrc=2349624&ssuid=Bq_PmGF8QpG&var=&widget_ver=artemis&media=COPY
