What is less clear is that it can still take up to a week for them to process the order and dispatch the items before that 2-4 days starts.
So even though everything was in stock in the same UK warehouse, it has been sent out in 2 separate packages at very different speeds.
The extension kit arrived very fast. The laser and cutting beds have only just had their courier booked.... so I assume it will arrive after the bank holidays now.
One of the first things I need it to do is make some headstock facias, complete with logos. i have some 3mm flamed maple and walnut, so the plan it to cut two and swap the colours for the logo disc
First i made the drawing in inkscape, i changed the colours so it imports nicely into lightburn
Once in lightburn i can set the order, speed and power of each colour independently - they will be set for this file after I have done some cutting tests
and i can run it through the preview to make sure everything flows in the right order
in other words, i'm ready to go and itching for it to turn up!
Instagram
or this?
* Hamer SS2 & T62
* Music Man Luke 1
Please drop me a message.
What it can engrave is coatings on metal, which potentially gives a few options for a Zemaitis inspired build
I could spray the metal first and engrave through, just leaving the painted design where i wanted, but that could wear easily... or potentially do that as a negative and then chemically etch the design into the exposed metal before stripping the paint.
I will try both at some point.
I did start one by hand a few years back, but messed up on the rope border
Instagram
Best investment I ever made
The laser is sooooooooo heavy I had to build the cart under it with industrial casters (and a materials storage area).
Assuming I don't miss the delivery, the plan for the next few weeks is.
1) Build and connect - Done
2) Cutting and engraving test patterns - Done
and assuming it all works okay...
3) Wedding lanterns - cutting 3 mm ply - success
4) Headstock facias/logos - cutting and engraving 3mm hardwoods - success
5) Pickup templates - 6mm ply
6) Scratchplate template - 6mm ply
7) Pickup winder box - 6mm ply
8) Fretboard cut/engraving/marking out - various hardwoods
9) Guitar templates - 6mm ???
Instagram
All the parts are nicely labelled and it went together quickly.
There were a few bits not covered in depth, but the sculpfun YouTube channel answered them all.
Frame
All wired up and ready to go
And I got an engraving test card done on one of the included bits of ply, says S10, but its the S30 I have
Instagram
Instagram
First thing, like with all maker machines, is to make something to help use the machine. I made some holding pins out of 3mm ply
Then i used those to hold a bigger sheet to make a wedding lantern
Now onto the first guitar task - headplates. I picked out some wood first. The maple is actually 4.5mm thick, walnut is rough sawn and varies from 2 to 3.5mm
it worked really well. It would obviously look better if i had thicknessed them first, but as proof of concept this is great
an edge shot of the maple, this is a good cut, no burning to speak of
For reference, the maple was cut at 300mm/m, 80% power, 2 passes. That took about 5 minutes. The thinner walnut only needed one pass, so half the time.
The ply cut in one pass up to 500mm/m. It didn't quite make it all the way through at 600mm/m. The lantern took about 35mins in total, but has a lot of detail to cut
Instagram
Instagram
Instagram
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Diode laser's aren't that powerful in comparison, but can still do a lot of damage. However the beam should only ever point directly at the workpiece, and the biggest risk is it being reflected off something.
CO2's on the other hand bounce the beam of a few mirrors, so there is a greater risk of the beam pointing somewhere it shouldn't.
You can use whatever colour safety glasses you like. The shade just kills the brightness, it's the plastic that is enough to diffuse the beam and prevent permanent damage. Just like welding masks, it's the glass that stops the damaging rays burning your eyeball, the shade just makes it so you don't get blinded by the brightness and can see what is actually going on.
I've just spent the evening laying out a true 24 3/4" scale length, calculated with a straight rule of 18.
Took about 30 mins in excel and inkscape to lay out something bespoke like this. It says it will be 12 minutes cutting time to give me a board with marked/engraved fretslots and the inlays and board cut out.
Instagram
