Been a while since I've done a Warmoth build.
Not a bad start. The blocks on the neck are not the same dimensions as fender style, and it had 22 frets... but this get us in the right ballpark for the look needed.
I used some tinted sanding sealer to get a good base for later relic work.
Then sprayed a nice deep red.
My interpretation of Fenders interpretation of Cardinal Red
Still has some nice brightness when the sun hits it, Closer to Gibsons version of the same colour name. This is the same colour taken on the same camera 10 seconds later, just facing the other way
That is it for now.... onto clear
Out of interest, which tinted sanding sealer did you use?
Instagram
Instagram
Needs to look like a custom shop masterbuilt sig, but I was asked if I could make it feel like a 90's strat plus neck... minus the sharp edges
That meant doing things a little differently with the back of the neck. The worn through area isn't worn through at all. It had some dirt added to the grain, but was then sprayed as a light grey/brown tint, with no grey and more amber/tobacco for the unworn areas. This then all got coated in satin clear. It ended up looking more authentically old than the model it is based on.
I think that meets the brief. The custom shop style logo reads "Shifty - Foo Fighters". There will be many other tells this is not the genuine article, but hopefully not ones the non-guitarists will notice
Instagram
1st stage relic is done
Instagram
Watching this with bated GAS breath.
flanging_fed “
it's gone back to my cousin for him to put it together. I imagine I will see it in a couple of weeks for final setup.
Instagram
Not what I want from a Tele but it certainly looks the part and should be a fun little instrument
That colour is brilliant, too.
Yes, he added a Fender logo, but it's over the lacquer and not an authentic one. There are lots of other tells this isn't a Fender, such as the extra fret, inlay shape, lack of bullet, rear contour shape etc etc.
At the end of the day it's for a fake band anyway
But here is the £8k Custom shop version for comparison.
Instagram
flanging_fed “
https://m.facebook.com/story.php?story_fbid=pfbid0tmS7n1uJCSwLN7zHaTGFmqVUhD5UuP1rJ1x5dpXdfnzTCsPcfqqhn78SKcJUYBStl&id=100063475033489
Instagram
https://www.instagram.com/tv/CtDGvl0I2Gd/?igshid=MTc4MmM1YmI2Ng==
Instagram
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
He sent it off to tinytone so they could make him one in greyish minty shade, which suits the vintage fender vibe much better. I knew they had the right shade as I had recently been sent some for another refinish project
Instagram
