Acoustic Build - GS Mini Style
  • WezVWezV Frets: 17500
    edited March 2023
    I picked up a acoustic neck angle jig from Radius Dish UK.  It arrived yesterday.
    It does both dovetail and mortice and tenon  neck joints, so I fancied trying my first dovetail.
    That may have been a mistake as I overshot the body route for it by a mm each side, .. but i was then able to use the jig to  recut it wider and make a filler piece.  I made the filler piece wider than the original cut to ensure it was strong enough.  I was then able to reroute at the correct dimensions.  You can see it is the darker mahogany fill either side of the re-routed dovetail here.
    Next time I will do the body route first and cut the neck to match.  It is easier to do fine adjustments on the neck part of the jig.
    I should have practiced with the jig on scrap a bit more first, but I'm quite happy with my save.  Everything feels nice and solid
    with oversized fretboard blank
    The bridge is an aftermarket one, but i quite like it's design
    I've been avoiding that rosewood fretboard blank for a few years.   It is quite pale, and therefore the back of it had been used as practice for staining paler fretboards
    But now I've put it through the planer and added a radius and slots, it's actually not as pale as I thought.
    The body has been bound.
    Nothing fancy, just simple cream
    0reaction image LOL 7reaction image Wow! 1reaction image Wisdom
  • BigMonkaBigMonka Frets: 1820
    That's looking beautiful.
    Your stream of photos from the different stages really hides the effort and craftsmanship that it must take between each step!
  • Andyjr1515Andyjr1515 Frets: 3129
    Looking really good @WezV ;
  • TTonyTTony Frets: 28444
    Had to add a comment rather than just another wow.
    The comment is “wow”.
    Looks like another great piece of work Wez.  Lovely timbers and a great save from the fireplace.
    edited April 2023
    i've not been totally happy with the soundhole decoration on this.  The cavity cut fine, but some of the walnut strips were not evenly thicknessed, leaving a gap here and there
    but the purchase of a laser cutter brings new opportunities
    The first thing to do is a jig to fit he sound hole and allow me to accurately cut a new channel.
    so i cut this
    the 3 bits on the bottom will be laminated together.  The smaller circle will allow the jig to sit straight in the soundhole.  i've done two layers of the main template to allow extra thickness
    i then designed a simple rosette and cut a load of walnut and cedar from the offcuts of this body
    i put some double side tape on one of the jig offcuts and started piecing it together
    it's possibly a bit too fancy and  i may just go back and cut some new strips... but this new toy is fun!
    that got soaked in super glue overnight, giving a solid rosette which fits really nicely in the matching template
    still bumpy with glue, but should be nice once levelled off
    I went with the rosette, also used a headplate cut from the spare bits of back wood
    The neck is rough carved too
    fretted, neck glued in, and sealer coats on
    Also, now there is lacquer on it I think the mystery neck wood is likely Dark Red Meranti, not mahogany.
  • BillDLBillDL Frets: 9018
    It's amazing the difference when even the first sealer coats are on.  It was lovely before in the bare wood, but is really beautiful now.  I like the figuring in the neck, the bookmatching of the back, and that rosette is something else.
    Yeah, I got pretty lucky with the woods.
    The neck figuring is very subtle until the light hits it, then it just pops.
    I was going to add a walnut heel cap, until I realised that orange patch in the walnut led nicely into the neck wood.
    Nearly done
    I still need to buff out back and sides but couldn't resist getting some strings on
    Initial impressions are good... just need a slightly taller saddle as it's too low action and choking out higher up the neck... but I would rather a little too much neck angle at this point than not enough
    0reaction image LOL 6reaction image Wow! 1reaction image Wisdom
  • droflufdrofluf Frets: 4211
    Looks great!
    Sporky: "Drofluf is a reverse vampire, who always appears in mirrors."
  • That's looking really good - nice use of the laser cutter as well.  Did you do the engraving on the trough in the background as well?
    Nah, that's the brand.
  • robertyroberty Frets: 10932
    This looks amazing @WezV. The rosette is so pretty
  • normula1normula1 Frets: 662
    Have a wow, looks fantastic
  • Jez6345789Jez6345789 Frets: 1822
    Lovely work as always
    Did I miss abit as have had a few glitches lately as you zipped the box up quickly did you just do a basic x brace based of Martin or did you do more work to tune the top scallop braces etc.
    looking good
