Amp gain types
xHymnalxHymnal Frets: 255
I can recall amps with gain types that most overdrives/ distortions seek to emulate but has anyone ever come across an amp which has a fuzz gain structure? I.e. you turn the gain up and it becomes saggy and fuzz facey?! Just out of curiosity more than anything!
  • Early Fenders when dimed with a high output humbucker get fuzzy. You get some insight with this, although not particularly high output guitars are being used.
  • Dual Rec with gain really high in at really really low volume? Not fuzz facey, but sort of sounds like a big muff pedal.
  • ICBMICBM Frets: 74500
    Yes, a lot of 70s solid-state amps do.
    The good news is that they're dirt cheap.
    The bad news is that a lot of them are not tolerant of doing that, and the smoke can come out...
    Relatively reliable ones that will get close to it - and have master volumes, and don't have to be cranked fully to do it, so they tend not to blow up - would be some HH models, and early Peavey Centurys.
  • 57Deluxe57Deluxe Frets: 7406
    great clip!
    <Vintage BOSS Upgrades>
  • stevehsteveh Frets: 277
    Yes - a Lazy J20 (ie Fender Deluxe clone) when dimed is, to my ears, a "fuzzy" loose type of distortion.
    Not at all like a tight Marshall or similar.
