If not and you have total freedom, the top E saddle should be set 95% of the way forward and that position at the exact scale length - no string will ever intonate shorter than that, so there is no point in allowing for movement that way. The only reason for the 5% is to make sure that drill 'wander' as it goes into the wood grain doesn't accidentally move the bridge slightly.
But if its a normal tele I would position it based on routes and parts. And just double check it's correct before drilling
Instagram
