FS: Fender G&G Brown Tolex Hard Case - Strat
Hi folks, I have a G&G brown tolex case that came with my AVRI2 ‘61 Strat.
Wondering if there is any interest at £170?
Would need to be collect only from Harrow HA1.
Please PM if interested, I can sort pics then, but it’s one of these (edit - turns out after Rob’s post below it’s similar to but not the same).
These cases with the AVs/AV2s aren't standard G&G cases you can pick off the rack and are difficult to replace now if you ever wanted to (although they look similar - notice the interior is different - and if its the same, the shop gave you the wrong case) as is the dimensions (the AV cases are usually thinner than the standard G&G deluxe).
