Do you have a template? Or a router table?
You should remove as much material as you can first either with a drill or saw.
Go slowly, don't try to remove too much plastic too quickly or or can grab and you'll get tear-out.
I made this one the other day from a no-hole pickguard.
I had a homemade router table but it’s quite old and has warped, so, um, no. I was thinking of spending quite a bit of time on making a template or being careful with fences - my router experience tells me it’s all in the prep!
I take your point about removing the bulk by some other means and then cleaning up the edges with the router. Smashing. Thanks again.
Nice job BTW.
