Stew-mac dremel binding attachment.
Radius Dish UK Tru channel style binding jig.
Handheld brass purfling cutter to mark, then knives and chisels to clean up
They all work. The proper binding jig is easiest and safest, but obviously costs more and take up more room
Edit... missed that the neck was on... knives and chisels all the way for that cutaway section
Instagram
If the rest of it has been done with any half-decent rig, then at least you will have a pretty decent shelf that you can use as a chisel platform once you are down to the final 0.1mm's of removal.
I find that the Crown stubby chisels from Axminster are ideal for this kind of thing.
