I have a Hot Rod Deluxe... and V1 started getting noisy. I also noticed a blue tinge to one of the power amp valves.
So after reading some 'experts' on the Fender (and other) forums blathering about fitting a groove tubes 5751-M and how much clearer they sounded... I thought OK why not.
I also slotted in a pair of Ruby 6L6s into the power stage (they were lying around) and biased it up accordingly.
The result?
Horrible. Hateful sounding cleans that were more 1 dimensional than a line drawing and the drive channel had no go and sounded like it needed Sinex. I also found that on clean single notes, the decay wasn't linear and would break up in a fuzzy, almost broken sounding way.
So more money later, I've bought a GT 12AX7R and a pair of GT 6L6s (re biased again) and it's back to sounding wonderful again. Fwiw, I tried it with the Ruby power stage and the 12ax7 and it was hugely better... Just nowhere near as sweet sounding with the GTs.
So the lesson learnt is that if you like the sound of your amp, do not assume that advice 'improving' your tone is actually going to do just that. The other person could be a deaf pillock who likes things to sound broken!
Valves vary from one to another anyway. I still think there is a market for a high quality modern valve (as in, made in the same way as old mullard, telefunken etc). I don't see why they can't do it? I don't even see why it would cost a great deal more.
I really don't like 5751s. To me they sound an odd combination of too smooth and harsh at the same time… hard to describe, but nasty.
It changed a great sounding amp into something truly horrid.
I took it out. I agree with you- some things may well improve the tone but a lot of these things that people swear blind, "Oh you have to do this, it sounds crap unless you do!" are BS, in my experience. Or maybe they genuinely work for the person who's suggesting it and his/her specific situation, but that doesn't mean it'll work for you.
