Hi Everyone, i am new to the site so please be kind if i have repeated an old thread.
I am looking for a new amp that has two channels, or a single channel with a good and reliable effects loop so i can run a boost pedal through it. I play classic rock and therefore only need a crunch and lead channel, i get "clean" from dropping the guitar volume.
I had a Blackstar stage 60 but it was a bit flat. I am using a Orange Rocker 30 and Tiny Terror combo in a dual amp set up... but its a pain TBH.
Thinking of the Marshall Vintage Modern or the JVM205c. I have palyed the VM and it sounds good, but the owner told me the loop was aweful and it was the most unreliable amp he has ever used.
Cannot get to play the JVM locally.
Anyone have any thoughts or suggest alternatives please?
Thank you
Have you considered a Jet City?
Interesting I heard last night that apparently Mike Soldano has stopped his involvement with Jet City? That's total hearsay, by the way. A guy I know on another forum heard from another guy he knew on a different forum who allegedly contacted Mike about something and was told that ) ).
But yeah Jet Cities are very hard to beat for what they cost. Only thing I wonder is if they're maybe slightly modern-sounding for the tones he wants.
Otherwise, I'll say jet city (crunch sounds amazing). I'm possibly getting a jca22h but the 50 watter is apparently the pick of the bunch and better at a range of volumes, down to bedroom.
The rocker sounds awesome.... but it does not like boost pedals for solo work, it is okay in a single guitar set up, but it has not got the headroom for a big boost with two guitar bands if that makes sense.
Trying to find a local jet city stockist also been put on to Marshall TSL 60?
Thanks guys, any other thoughts are always welcome
Someone mentioned budget, i am aiming to spend up to a grand all in
monquixote
wow, this sounds superb!!
http://www.thefretboard.co.uk/discussion/22662/fs-top-hat-emplexador-killer-boutique-marshall-clone
Cheap used, too.
If you play true classic rock, you could look at a reissue JCM 800 or super lead as you'll get the classic Marshall sound but with an FX loop.
You could also look at the originals as well as they can be had cheap if you search round (case in point, I bought a mint 1978 JMP SL II yesterday with cover, original Mullard EL34's that had recently been serviced by Marshall for £625!). Any competent tech can put in an insert / series FX loop in for not a lot of money.....
A Marshall Jubilee should be another consideration maybe. The loop is pretty decent on these and it has two channels (one of the best lead channels you will find). The prices like everything in the guitar world seem to be coming down a lot as nobody seems to want to pay for high end gear anymore.
What's your budget? Might help with some of the suggestions.
Ask for something vaguely Marshally with an effects loop if you need one. Done
I've played through a marshall vm and they do sound good, but as ICBM says, they are not well made. The Laney GH i have also played through sounded better and are very well made...i recently sold a very early JCM900 which was a 1.5 channel amp...single channel but with a footswitch for a volume boost...they are called High Gain Master Volume...or 2100. That sounded great as good as the laney but slightly cheaper.
Ive also had a jet city 50w which was also lovely and redonculously cheaper! I got mine modded to KT66 powertubes and added a depth knob...and it turned the amp into a beast. Would be great for rock...highly recommend it. If i was to get jet city again though, i would get the 100hdm...you can switch to 50w and it has a depth knob built in.
@Eartrumpet if you're local to me (hampshire) andwould like to try a Jet City i have the 22H head youo're more than willing to test.
I'm a recent convert to Jet City's amps and i'm loving them. Gig week in week out with the 22H and it's fantastic.
That is a very kind offer, unfortunately i am miles away, North Leicestershire.
I am going to try a JCM800 this week, based on advice and i have also been offered a Boogie DC5 but i think that will be the "wrong" sound for me.
A dual Terror has also been suggested, i do like the Orange sound, just the solo boost option i struggle with
