What is a reasonable tolerance for a custom order body drill hole?
JDD24JDD24 Frets: 1
edited August 2023 in Making & Modding
Hi Everyone,
I recently spent £372 on a body from an off the shelf site. It came out super nice, really lovely quilted maple top on, but the Hipshot bridge drilling is out. The drill spacing for the outer 2 mounting screws are 1.27mm further apart than they should be. The result of this is that the bridge will go on but those two screws don't sit flush as they are forced to the edge of the hole on the bridge and so cannot sit in the countersink for the screws in the bridge. When I emailed them they told me its not possible as it is done using CNC and when I confirmed with images showing the measurement, they said it's within tolerance. So, my question is, what is acceptable tolerance in this situation?
  • SporkySporky Frets: 30210
    If the bridge doesn't fit then the holes are not within tolerance.
  • chrisj1602chrisj1602 Frets: 4165
    That’s not a good response is it? Poor from them.
  • JDD24JDD24 Frets: 1
    edited August 2023
    edited August 2023
    They sound like a bunch of pedantic but sloppy bodgers.
    edited August 2023
  • robertyroberty Frets: 10932
    That's a real shame. It is infuriating when a company fucks up costing you time and/or money, and then are defensive about it and won't acknowledge your frustration. Literally the worst way to handle a complaint
