We should probably have done this a while ago, but thanks to a reminder from
@Fiftyshadesofjay we've finally done it.
In terms of what goes in here, there's obviously going to be a lot of overlap with Amps and FX. As a general guideline, if it's something to do with the digital part of an amp, or it's a modelling pedal, it goes in Digital & Modelling. Obviously if you're posting about a Helix, AxeFX, Kemper or Quad Cortex...yep, this is the place. We've moved a bunch of threads in here to give a general flavour of what belongs, just to lend a bit of a helping hand.
I suspect there's going to be a fair bit of suck-it-and-see with this, but let's just see how it goes. Have at it!
<space for hire>
Will be some nuance needed in how some stuff is discussed (Fender Tonemasters and Strymon fx and similar will crossover a lot I guess) but we'll muddle through!
https://www.thefretboard.co.uk/discussion/99368/separate-modelling-section
And...there's still the option of reversing the change if it turns out to be ridiculous
https://youtu.be/GEnx9xS79Lc?si=tJRgWy51Xky7Wv-s
Hope that helps.
