Pedal builders - where do you buy your electronics?
Hi all,
I've recently started building a few pedals on Vero board and wondered where you guys are buying your electronic components? I've been using CPC but have to say they have really become pretty poor. I received an order this week, completely missing ten line items even though their delivery note implied they were shipped! So I think it's time to look elsewhere...
Cheers,
Graham
  • springheadspringhead Frets: 1704
    edited September 2023
    Rapid are good. Banzai if it’s something unusual/specific you can’t get elsewhere. I did quite a few orders from Small Bear in NY for really niche items, eg matched ge transistors, Univibe LDR’s.
  • Excellent, they look good, I will try rapid next I think. Many thanks!
  • euaneuan Frets: 1942
    Tayda are good too and offer UV enclosure printing.
  • Thanks @euan that looks pretty interesting. Have you used their UV printing services at all? Would be interested to see some examples. Cheers.
  • equalsqlequalsql Frets: 6375
    I like Bitsbox. They do some pedal kits as well as components .
    https://www.bitsboxuk.com/
  • SporkySporky Frets: 30220
    I mostly used Rapid, with some parts from RS. I'm not sure I can remember where I bought footswitches.
  • Danny1969Danny1969 Frets: 11014
    Rapid have a whole stompbox section now
    https://www.rapidonline.com/audio-components/stomp-boxes
    For electronic components I use CPC .. they do mess up occasionally ... especially with small quantity and physically small parts. But if you buy in multiples of at least 10 then it's cheaper and less of an issue.
    I also recycle a lot of components like opamps, transistors, resistors  and caps from scrap electronics. I built a tube screamer clone once out of nothing more than a broken computer speaker and a phone charger.
    For top quality more exotic components keep your eye on Ebay for things like "job lot electronics"     ... some people don't really know what they have. I once brought over 2K's worth of new Neutrik connectors for £38
    0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • Thank you all for your suggestions, there are quite a few there I will definitely try!
  • YorkieYorkie Frets: 1694
    As others have said, Bits Box is great. And FuzzDog has a good selection of the basics, and some components are cheaper and better than those at Bits Box, e.g. foot switches. Both send their stuff by 1st class, so in general you'll be getting your things in less than 24h.
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
    Banzai used to be brilliant for knobs. I've still got - at a guess - a hundred or so.
  • SteveFSteveF Frets: 543
    I'd echo the recommendations above - another shout for Tayda for some stuff. I don't tend to use them for ICs and the like but for bulk buying common resistors, pots and switches etc they are pretty good and fairly cheap.  Their Hammond style powder coated enclosures are also perfectly good and well priced.  I have used their UV printing once and it came out well.  The only 'issue' was my own - I had not rounded the corners on my design, so it crept over the edge at the corner.
    IMG_1865.jpeg 155.2K
  • That looks really nice! Thanks for sharing. :-)
  • I'm jumping in here with interest. I built a couple of pedals from PCBs bought at some DIY pedal kit place that was popular many years ago. I was OK with the soldering and stuff, but not so good with the enclosure drilling and putting it all together tidily.
    What I would really like to get me started is something more like a Lego kit where I can put the plugs, pots and switches into a pre-drilled enclosure, wire it up (maybe soldering), and add my own knobs and dials.
    I think FuzzDog do that, anybody else? I'll have a look for some build videos before I take the plunge.
    Yeah, FuzzDog does exactly that. Jed's Peds too.
  • Paul_CPaul_C Frets: 8092
    . . . and Musikding.
