Reverse fender
Maybe a stupid a question but would putting a left handed strat neck on a right handed body work? I'm after a reverse headstock.
  • WezVWezV Frets: 17501
    edited September 2023
    It will work, you might just need to add some new side dots and nut
  • On a modern neck, unless it has Sperzels, you will also require reverse handed machineheads.
  • paulnb57paulnb57 Frets: 3222
    Yes, these are both Lefty necks on Righty (ish) bodies, you just need to add or live without side dots and change the nut (sometimes you can rotate the nut and recut the slots)
    Squier on “Eleven” and BooBoo on “Thing”
