Does anyone actually make use of the dual input channels on Fender amps when changing guitars?
CaseOfAceCaseOfAce Frets: 1445
edited October 2023 in Amps
... and if so..does it really cater for the volume differences from using single coils and humbuckers?
Most people generally just use input 1 and adjust volume elsewhere in the chain?
It seems Fender could reduce a whole lot of unnecessary circuitry etc.. if they just went to one input?
so why do they insist on still manufacturing amps like this?
  • ICBMICBM Frets: 73155
    It’s a historical thing - most amps designed after about 1975 do have just one input, but these are reissues of earlier amps.
    It’s useful for a few reasons - as a backup if the main jack gets damaged, to better match the output of an active instrument (both for volume and impedance), it allows you to run two instruments into the same channel (not that it’s very likely) and most usefully for modern players, you can use the second input as a splitter output to jumper the channels, or to another amp.
    I don’t find it essential, but overall I’d probably rather have it than not, and it only adds a tiny bit of cost.
  • impmannimpmann Frets: 12724
    No but I used to use them with an A/B box to give me a slightly quieter sound for certain songs/segments. Not quite as a 'boost' for solos, but a softer tone for certain rhythm parts.
  • No
  • LebarqueLebarque Frets: 3966
    I thought they defaulted to the same volume if you plug into both?
    They do - both the same as 1. (High, on amps where they're labelled high and low.)
  • YorkieYorkie Frets: 1565
    I used that on the Bandit quite a lot. I had the pedalboard plugged into the low gain input, and used the high gain input for plugging straight into the amp. Footswitch to enable/disable effects loop as required, ready to play.
    It's convenient, and I do miss it now that the DSL has taken over.
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
  • Fishboy7Fishboy7 Frets: 2254
    Never noticed much difference really
  • Modulus_AmpsModulus_Amps Frets: 2623
    If you have a really hot guitar pickup input 2 can be helpful to get a cleaner tone.
  • Dave_McDave_Mc Frets: 2411
    I've never used the low input until recently, but I got a 5F2-A clone and humbuckers (even vintage output ones) seem to sound better into the lower input. I really wasn't expecting that, usually it just sounds worse!
  • I use both inputs on my Fender SKX 100r.  High input with the band/gigs. Low input when I’m at home. I just prefer the sound like that. Mellower at home, cuts through better at volume.
    It’s even more pronounced on my Marshall JCM800 though. I’ve ended up using almost completely different pedal boards depending on if I want to use the high or low inputs.
    That's a different thing - the High and Low inputs on a 2203/4 circuit are totally different in gain, there's an extra valve stage for the High rather than just a resistor divider between the two. (But oddly, the Lead/Bass 12/20/30 do use a divider, although it's a bigger drop than the standard 2:1 type in two-input Fenders and older Marshalls.)
  • mburekengemburekenge Frets: 1091
    I use 'em on my Victoria 5112.
  • On a gig I always use the second input of the normal channel on my ‘ 74 Deluxe as a pedal platform and it sounds great for any guitar I use, with plenty of punch. If i am using a Jazz Guitar indoors I will generally use the second input of the reverb channel to optimise the “clean” sound. I’m used to having this option on my amps for many decades, though I also happily use a Carr Rambler some times.
