pickup foam / rubber question
Hi guys
Just replaced the pickups in my Squier Jazz bass and its a classic "direct mount screws plus foam for height" setup.
I want to get the pickups a tiny bit closer to the strings but I've run out of foam.
Is there a recommended method for "shoving more foam" in there? can I just shove an extra bit of material (and if so, what?) in there?
  • I used a bit of sponge from a scourer pad beneath the neck pickup on my Tele and 3 years on it’s still doing the job.
  • Dave_McDave_Mc Frets: 2462
    Did it improve the clean tones?
    (Sorry  =) )
    9reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • BillDLBillDL Frets: 9018
    I found the sound to be a bit rough, as though it was soaking up the tones.
    @UnclePsychosis ; The "proper" way would be to:
    Slacken the strings off, slide something thin down between the edge of the pickups and the body, and mark then measure the existing pickup heights.  Also as a double-check, measure their heights from the body surface.
    Unscrew the pickup screws and lift the pickups out.  Work out from the pickup thickness and the other measurements how thick you need the foam to be under the pickups to raise them to a bit higher than you will want them to be set.
    Cut some pieces of foam to the needed thickness and the right shape with a sharp knife or scissors and place them in the cavities.  If there's already foam in there (should be) you could just add thin pieces of foam on top.
    Rub a candle or smear something waxy on the threads of the screws before replacing the pickups.
    The black foam that comes in effects boxes and other musical equipment usually has the right amount of bounce vs firmness to push the pickups upwards without making the screws too hard to tighten.  You can usually get a good idea by just squeezing it with your fingers.  Try to use the foam that's softer and denser and with smaller bubbles than the "drier" and "scratchier" foam with larger bubbles, because that doesn't perish into powder as fast.
  • SteveRobinsonSteveRobinson Frets: 7343
    edited October 2023 tFB Trader
    It doesn't have to be all foam, just enough to allow adjustment. You can always use something hard such as a piece of thin wood to give a bit more height.
  • Thanks folks.
    I had to order something else from axesrus anyway so for the sake of a few quid I've just thrown in some thicker pickup foam to the order. Much easier than faffing about.
    edited October 2023
    That's much better than mine, but I got the LOLs! Maybe it's because it was hidden in a bigger post- I've noticed that before, someone posts the same joke a few posts up alongside a longer post and gets no LOLs, while someone posts near enough the same thing- by itself- a few posts later and cleans up on LOLs...
    Life's not fair... I've given you an LOL anyway.
    Thanks folks.
    Yep that sounds like the most sensible plan
    As an added bonus it might stop me making low quality jokes.
    It probably won't, to be honest.
