If you're going to take it in anyway there's not much point in going further with trying to find which it is. The good(ish) news is that even if it needs a re-valve - which is best done as a full set - 1 and 2 should be safe to keep as spares. But don't just change the valves without being sure it's not the bias.
Just beat me to it IC!
A set of 6550s is well over £100 for JJs I see so you do not want to risk anything.
Dave.
I have a 22w two rock that is red plating on one side that started With a low level persistent hum
I thought about measuring the screen grid on that . Then I sobered up and realised I only have a vague idea of what I'm doing
I'm also very wary of capacitors
It's a 2 power valve amp
I tried brand new valves and still had the same issue
I have a valve tester as well and ran all the valves through it with passes (although experience tells me not to 100% trust the test)
It is confined to one side which is why I was thinking screen grid?
User replaceable? (Not bad with an iron)
Anything else I should look at or is it off to try and find a tech?
Appreciate the advice
