I feel this has probably all been answered before but I'm struggling to find all the relevant threads. I've certainly seen a recommendation from
@notonlybutalso which I'm considering, as @jaymenon is offloading a load of valves at the moment.
So first of all I am going to replace the loop valve for an ECC82/12AU7 as recommended by a tech from PRS when I first moaned about the slightly noisy loop.
Then I would like to put in some ECC81s/12AT7s in the drive side to take some of the edge off and make the gain sweep a little more forgiving. This is something I've seen suggested before.
My question is this: according to the following schematic would I have to replace V1, V3 AND V4 or just V1 and V3 (or even V3 and V4)?
You get less overall gain on lead and more of the gain control becomes usable. I didn't use the loop on mine so left that alone but the recommended V5 swap sounds right to me.
The 5751 has about half the gain of a 12AX7 and I would suggest swapping just V3 first and seeing how you like it as it may tame it enough.
I'm not sure the 12AT7 is your best bet in the lead positions - @ICBM or @ecc83 might chime in here as there is something I remember about not being always a drop-in replacement for the higher gain ones.
