SOLD
CahrlieCahrlie Frets: 40
edited January 14 in Amps £
https://imgur.com/a/nVDrFV4
Mint condition, 38watt hand-wired EL-84 goodness from Dr Z, with spring reverb.
Has just been fully serviced including brand new power amp valves & rectifier valve.
Incredible condition, complete with foot-switch.
£1250 - collection from Cambridge please.
Any questions please let me know!
Many thanks.
From DR Z;
The MAZ 38 is one of Dr Z’s most enduring designs.
It is the perfect combination of sound and power.
4 EL84s with no negative feedback give you a wide pallet to work from.  The 38 has enough clean headroom to make for a great pedal platform and gives up the goods for a great drive sound at reasonable levels.  The 38 can satisfy many different styles and playing approaches.  You are able to dial in mid 60s blackface sounds as well as UK flavored chime.  The Dr. Z MAZ 38 is a truly versatile amp for the working or studio musician. Whether your forte’ is Blues, Country, Roots, or Rock, The MAZ 38 will fit the bill.
The front panel features Volume, Treble, Middle, Bass, Cut, and Master.
The back panel features a 4,8, and 16 ohm speaker out. An effects loop, Reverb and EQ bypass function.
The footswitchable EQ bypass gives a great lead boost which effectively makes the 38 a 2 channel amp.
The 38 is powered by a quartet of cathode biased EL84s and a 5AR4 rectifier.
