Burman Pro 502 - 2x12 combo
goldtopgoldtop Frets: 6342
edited July 23 in Amps £
Seems to be a 1977 model, from the cap codes. Some dings and scuffs that you'd expect from 46 years of life, and commensurate with the weight. It's HEAVY!
50W, 2 channel model with reverb. Cascaded gain on Channel 2 - sort of a "British Boogie". Old hardware was suffering - Philips screws being 'rounded out' - so all replaced with new. Old parts kept in a baggy.
One bad point: the indicator light has failed and I've been unable to source a replacement. May need a tech to creatively disassemble the original and insert an LED/etc. So it's priced accordingly.
Price: £450 collection only from Cambridge
bur01.jpg 528.3K
bur02.jpg 464.7K
  • Amazing amps,I've owned a quite a few over the years,and still have my 502
    Best of luck with the sale.
  • My back hurts just looking at it.
  • BorkBork Frets: 260
    The 501 is less of a lump.
    [This space for rent]
  • goldtopgoldtop Frets: 6342
    price drop bump: £650
  • maxdmaxd Frets: 46
    I had a 501 for many years, they're such good amps, so very versatile with their three channel gain allowing all sorts of gain cascading allowing super clean, thin, thick, creamy saturation, to wild overdrive.  Based loosely, as I understand it, on the then new Mesa Boogie amps.  Don't they have K88 power tubes, like 6L6s but better?
  • Mike58Mike58 Frets: 162
    edited February 23
    Still have mine, bought new in 1978 for £315... just The Best build.
    good luck with the sale, they are so good.
    Mine still has the Gold Lion 77s ,very little info about modding or valve substitutions online.
  • FunkfingersFunkfingers Frets: 14921
    Paging @HarrySeven ;
  • Had one for ages - very cool amps. Traded it around 3 years ago during one of my periodic gear culls.
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
    Back
    Up
    My
    Pretties
  • prowlaprowla Frets: 5038
    I had a Pro 4000 HD bass amp; it was heavy as a small planet and slightly underpowered.
    £600 bump
    £550 bump
    Trade bump: looking for a Kemper Powered Kabinet
  • HogwashHogwash Frets: 4
    They cost more than a Marshall back in the day.....
  • VoxsupertwinVoxsupertwin Frets: 341
    They feel like they are screwed to the floor!
    ^ Indeed - it's those yuuuuuge transformers. I used to avoid AC30s because of the weight, but I must have had a bit of a blind spot when buying this one.
    edited March 23
    £500 bump - MUST GO, so interesting trades possible.
    bump
    bump
    bump
