Quick mock-up with parts.
Tidied the ends up, but still some way to go with fretworkery
I also took some time to draw up the wiring diagram. I think you can tell that I am a graphic designer
Finished version (well, I may revisit ...)
Drilling trem claw holes
The abalone fretboard markers were too dark, so I replaced them with white pearl.
String trees added.
Headstock decal elements created in Adobe Illustrator, printed onto waterslide paper, applied to the headstock then varnished over when dry.
Pickups dropped in for fitting test
Some Pix:
Instagram
