I have a head and cab and a 1x12 combo at the mo.
Bear in mind I like a 2x12 at least which always weighs a ton in combo format, might not be such an issue for a 1x12.
Two Rock CRS 50
Friedman BE100
Selmer TnB 50
Four Cabs
PRS Stealth 2x12
Marshall Stereo 2x12
Zilla 1x12
Got to have proper amps and decent cabs, if you can plug straight in and feel inspired then it’s worth it
I live out of the way in a detached cottage, so I don't have to worry about neighbours, so tend to use #3 a lot. If I'm writing or short on time, I tend to use #1.
Main valve amp, with a few pedals and shit - in main "office/music room"
little Blackstar Silverline for "plug and play" in bedroom (in case Mrs bert using offce room)
THR-C for outdoor shenanigans
The amps I made also share a common chasis size and I do swap them between the combo and head shell sometimes.
That said, i generally use IR cab files to fine tune recordings now, so I don’t need to mix and match much now, if at all. Game changer.
Orange 4x12 cab and a Marshall jcm800 2x12 cab.
Combo’s…
Hook R20(for sale)
AC30S1
AC10
Wienbrock Gringo
Dr.Z Maz 18
Tweedy-Luxe 5e3
Boss Katana 50w
THR10
The Katana stays at work, the Orange 4x12 stays in the Transit, the rest scattered about my place. Gotta clear some really as I’m running out of space…but they all sound magnificent.
Cabs not used/kept at home - that is what a decent load box and impulse response is for!
Some amps the combo cab shape/size is very much apart of the sound, so that is something to be aware of.
At least some people have several combo amps so I wouldn't be a complete loony. Although I don't play out - so that's a bit bad.
https://www.instagram.com/insta.guitarstuff/
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
