**Just wanting to test the water again on this... itchy feet**
I'm in two distinct minds about this but thought I'd put some feelers out and see what's around...
This is my custom order 2023 Suhr Modern, daphne blue, medium aging with jaw dropping lacquer checking. It is a pristine, fantastic, top-tier instrument but... I just find I'm missing the Suhr classics I sold to fund it and wonder if I maybe need to accept that the modern isn't 'for me'.
Full spec and pics below. Asking £2,700 posted.
If you’d like to meet – I’m based in Swansea and willing to travel 50-60 miles.
I may end up withdrawing this because every time I take it out of it's case I have second thoughts about letting it go...
I've got the shop's photos which I'll upload in an imgur album later.
Spec sheet is in the images but in summary:
Modern, roasted alder body, daphne blue, medium aging.
Weight: 7lbs2oz
Roasted 3A birdseye maple neck
Even C slim neck, compound 10-14 inch radius, rolled.
SSH+, ML middle, SSV neck pickups
Blower switch
Coil tap
Heavy stainless frets
Typical Suhr tuners.
Gotoh two post bridge with bent saddles (no bridge recess, spec sheet image says recessed but I changed it mid order, the physical spec sheet is correct)
Comes with original Suhr gigbag (yes, I specced it with a gig bag because that’s what I like, don’t hate me).
