@exocet they must be pretty good as I dont see them pop up used much
take a look at the metro amp type kits
Ive built a couple of JTM 45's and 50 Watt super bass plexi's based on the Metro amp spec kits which are the original circuits and can confirm they sound outstanding. ive had marshalls reissues and a couple of freedman's too all great amps but the kits sound much more open and detailed to my ears.
I also added a NFB switch to one of my JTM 45's so its switchable between Bassman Spec and Marshall
just installed some NOS mustards
https://www.ebay.co.uk/itm/186210534826
Not sure how authentic the design is and no connection with seller etc... just in case of interest.
Also I have the Wienbrock ME-5 which is a bassman with a 2x12" so a lot easier to manage, you might be able to pick one up fairly cheap!
Edit; think I might be in for Superlead as well. I reckon these could make a great duo.
Bandcamp
Bandcamp
Depends if you want new, your budget and time scale. No one will be sitting with stock.
https://www.bax-shop.co.uk/amp-head/electro-harmonix-mig-50-amp-50w-valve-guitar-amplifier-head
Appreciate the suggestions - I've made a note of all those names; something tells me I'm gonna want more amps at some stage...
