coiled component leads in valve amps
I was watching a youtube video from @RiftAmps in which Chris goes through a Pro Reverb amp and highlights some of the issues with it (linked below). At about 7m43, he points out some component leads that have been coiled in an unusual way.
I found something similar in a Marshall I repaired recently, although not as neat and tidy:
I guess the idea must be to add some sort of shock absorption to protect the solder joint, but I can't see why that would be necessary for small components.
Ah well!
  • ElectricXIIElectricXII Frets: 1265
    Also possibly to raise them off the board to avoid them getting cooked?
  • KurtisKurtis Frets: 1162
    They couldn't find their snips?
  • robinbowesrobinbowes Frets: 3121
    You can do that without coiling the leads.
    Heh, possibly.
  • ICBMICBM Frets: 74503
    The only thing I can think of is an idea that it might help protect the caps from the heat when soldering the wires a bit, just because the heat will have to conduct further... but it's not really an issue anyway if you can solder properly.
    Otherwise it looks pointless.
    The example in the Rift video shows the same thing with resistors.
  • jasonbone75jasonbone75 Frets: 691
    Paul Reed Smith probably told them it improves the tone...
  • KeefyKeefy Frets: 2473
    It’s a good idea to protect components from mechanical stress when soldering their leads but that seems excessive.
  • MartinBushMartinBush Frets: 273
    You might do that sort of thing when installing component in something like a valve radio where tag strips are used. I wonder if those components had for some reason been prepared for a similar use, but then ultimately used in a different setting.
  • thermionicthermionic Frets: 10019
    edited January 24
    The extra inductance helps reduce ripple on the dc supply.
