I've got zero experience with using midi in any setting. My covers band have some songs that would benefit from additional noises and I'm wondering if a midi controller would fill the gap. Something like an Akai MPK Mini hooked up to my MacBook.
What software do I need? Are there any free or low cost options, or does the Akai come with something usable if bought new?
I want a Jew's Harp, some synth sounds, samples, cowbell, strings. Can I download free or bought packs which will work with the software?
Finally, we sometimes use my Roland Go 88 which advertised that it does midi. Any thoughts on using that as the controller? It's a bit bulky but already paid for.
TIA
yep... we do a mix of the two depending on the songs.. some are full click track.. some are partial.. some are just for added mid song fx..
https://loopcommunity.com/looptimus
I actually have a couple for sale.
Football is rubbish.
I like the idea of a sample pad, but not seeing anything in a sensible budget.
The Akai MPK Mini would fit in my home studio as well as in small pub gigs. I've got a MacBook to plug it into.
I don't really understand how they work though. How easy would it be to switch from strings on the keys to an organ or synth? Presumably you just use some software you assign which midi signal does what.
If I understand your needs correctly, you want to trigger some samples (as opposed to actually playing keys). The MPK‘s pads would be ideal for this…if it was feeding into, say, Studio One, I would use its ‘drum machine’ instrument and load-up my samples to a bank of virtual pads.
Next question is which software options can I consider for my needs - live playing? I think GarageBand will be fine for recording at home.
Are there free options that are worth considering?
Where might I get samples from?
I was thinking that there must be a more lightweight software approach for this and these are the first few hits for a Google on "standalone sample triggering vst":
- https://vi-control.net/community/threads/vst-recommendation-please.123299/
- https://gearspace.com/board/electronic-music-instruments-and-electronic-music-production/1254295-what-do-you-use-simple-easy-software-sample-player-triggered-midi-cc-pgm.html
- https://gearspace.com/board/electronic-music-instruments-and-electronic-music-production/884129-triggering-samples-live-without-laptop-involved-hardware-suggestions-needed.html
I don't have any live experience of this...so I'd have thought others would be better positioned to advise.If they were specific samples, I'd be tempted to try and put it together myself...otherwise, there must be many 'paid for' sample packs out there.
