So I recently acquired a nice spec'd Custom Shop Strat - As usual it will spend a while on my bench for a check-up and set-up - When all was done, I was somehow disappointed - It wasn't poor but it wasn't what I hoped for and expected with regards to playability - And with such a price tag I don't think I should have accepted 'that will do'
So left it a day or so to settle in, but it was still not right and certainly not giving me any 'I'd buy that' vibe - Just felt to stiff to play and not responsive to a light touch - Might have been fine for a SRV style player who digs in more - As we know some CS replicas are better than others and have some 'magical mojo' in them that makes you buy that one - But rarely do you come across a dud - This wasn't a dud but it wasn't right
So I left it for a few more days, in part thinking 'oh well' and part thinking 'so what' - But equally a nagging doubt said to me that it should be better - So I thought let's give it another go and start again
Goes to show what a 1/2 mm tweak here and a gnats whisker adjustment there can make - It is not one single adjustment as it is a bit of everything in order to achieve the right 'balance' - A couple of nut slots needed a trim - Only a fraction of a mm - The truss rod needed to be straighter, ie less relief and again just a gnats whisker - And a tweak on the bridge saddles - Bottom line is a new beast that is now what I'd have expected
Maybe some guitars have a 'wider parameter' of adjustments within them, that still allows them to play well, with more relief + a higher action etc - After all, we all know that the finer details of a set-up is a matter of taste - But this Strat just did not feel right with more relief and a stiffer action - But now, IMO, it is what you'd expect/hope it would be
So next time you think your last purchase is not for you - Give it another tweak and as I said sometimes it is only a gnats whisker of a tweak here and there - No fret dress or plek work required (occasionally some guitars do need that as well)
Bottom line is it now feels like a 'new guitar' compared with how it was last week
As to how many bugs dicks are in a can of worms ...i think that's a rather large number!
bugs dick is metric equivalent of a budgies pube
I think it can take a while to get your set up spot on. A little tweak, play for a while, another tweak, and so on.
There's generally a fine balance between playability and tone.
I agree and I dare say a good tech will be better than me as well - But the key part is that sometimes only a tweak can turn a mediocre guitar into a great guitar - I've barely ever known a new guitar that can be improved with some tweak or another - Granted some of that might be tweaking to fine tune a set-up to your own taste - But nevertheless, regardless of price, most 'factory' built guitars can be set-up better than they are from when you first open the box/case
The negative though can be weather/temperature - My PRS Hollowbody is set-up to perfection by such a finite amount, that as winter becomes spring and summer turns to autumn it will need a truss rod tweak - Fine again once adjusted, but no room for negotiation as such, when it 'moves' a touch - If I left it in a 'that will do' mode then I can probably leave it in that state all year
Don't be afraid and not so sure it is experimentation - If you do it yourself, then make a slight adjustment from a 'known starting' point - Then you know where to go back to if you have to - But tweak a touch - Re-tune, check and play, then tweak again if required - The only dedicated tools you'll need if you haven't got any are top nut files - But otherwise most other adjustments are Allen key and/or truss rod wrench/spanner - As a guide line, if you are new to this then start on a cheaper copy - Most will need a tweak and generally such a tweak can radically improve all/most Far Eastern budget based guitars - You probably won't make a Squire Strat into a Custom Shop Strat, but you can make a poor Squire into a better Squire
From the amount of part exchanges I see, plus guitars offered to me for sale and the many I see for sale at guitar shows, the large majority are not that well set-up - Some very poor - So in many ways we are trading in, selling guitars that we think don't suit us, yet in reality a set-up will transform them - I NEVER EVER sell a part exchange, that comes my way, as it is/was - Every guitar goes on the bench as in the main I know it needs it and I can generally improve it in one way or another - In very simple terms the guitar is the salesman not me - If it plays well, feels, good and sounds good, then I'm in with a shout of a sale - If it feels and plays like a crock of shit then chances are you won't buy it
