Box to record amp from speaker out to USB audio?
allenallen Frets: 825
I have done quite a bit of searching, but does anyone know if there is a box that can connect to a speaker out that ALSO has a USB audio connection for recording. Would also need to have cab emulation / IR capability.
- I have got a two notes cabm+ ...It does everything I want, but does not have USB audio out
FYI The two notes can be connected to the 'hot' speaker out as long as there is either a speaker or load connected after it.
I could go for a 2 box solution and get a small usb audio interface that takes the audio out from the cabm, but was hoping to avoid having 2 boxes.
I know the Boss WAZA TAE can do it, but was also hoping that I didn't have to get a massive box to do this job.
