I play straight into a PA via some pedals including amp sim etc. Nothing too out of the ordinary in my setup. Some of my pedals have stereo out including my delay. The last pedal in my chain is an amp sim, which only has mono output, and the whole pedal board is setup as standard mono.
The new sound guy had 2 DI's setup for me, and was seemingly disappointed when I only wanted to go mono. My only reasoning is that I have never played with Stereo out from my pedalboard, and I don't even know where to begin, and whether it is worth the bother or not. Unless I am going to be using some weird panning effects (clue: I am not), is it worth going down the route of stereo out?
In my ignorance, am I missing anything amazing by sticking with Mono?
In an average venue most of the audience will be much closer to one speaker or the other so they won't hear the stereo properly if you use fancy effects, and it will make it harder to 'place' the guitar in the mix. If the soundman wants a bit more 'air' in the guitar sound they can always add a small amount of stereo reverb at the desk.
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
I think I will stick with Mono. I could in theory get Stereo working, but to do so would involve re-ordering much of my pedalboard. And I would have no chance to properly test Stereo sound at home where it all goes through one standard amp - the thought of testing a brand new setup from scratch during a brief live soundcheck does not really appeal to me.
From the sounds of what people have said there are no real life changing benefits of going stereo and indeed some potential pitfalls.
There are some tricks you can do that are quite useful .... if you have a dry ish side and a wet ish side then FOH can balance the level of effect coming from you to suit the room. This isn't easy to do from the stage ... often what you think is enough is way too much. Sometimes, with some people, it goes the other way.
For a nice IEM mix then always guitar effects in stereo, keyboards panned in stereo and toms panned across the stereo field. IEM's sound terrible in mono which is what puts a lot of people off them. We aren't used to hearing mono really. An IEM mix should be panned like a studio foldback mix so the brain can separate things.
Mic that bastard up.
