The original intention, which still works well, is for the bridge pickup to be the ‘lead’ sound and the neck to be the ‘rhythm’ - the neck pickup is cleaner and smoother than the bridge. It’s duller than a Strat pickup largely because of the cover.
If you’re an acoustic player and want to try an electric, a Tele is a good place to start - the sounds and the dynamics respond naturally in quite a similar way.
FWIIW, the bridge pickups on Keef's Micawber and Andy Summers' mongrel Telecaster revert to direct mounting.
The neck/Rhythm pickup was intended to provide a contrasting mellow sound for band work. It was also expected to do double duty as a pseudo electric bass instrument sound.
On the earliest two pickup Fenders, the famous both pickups at once sound came via the blend control. After the controls were revised to volume and tone, the both pickups sound involved wedging the selector switch halfway between positions 1 and 2.
@Funkfingers ... Keith's bridge pickup in Micawber is body mounted (on a small block of wood) because it's Lap Steel pickup ...
How do I know this pickup intimately? Because I was the bloke who rewound it a few years ago after it died before a gig.
Below are two copies I provided to Keith's tech in case the same happened again ... note the half baseplate :-)
it’s really weird playing with one on isn’t it, I put one on my tele while it’s hanging on the wall but take it off to play, as god intended
BTW the neck pickup is great for the 5 percent of the time I use it. The bridge pickup has that ability to distort and not distort at the same time on a fairly clean amp. It's strange. I recently got a tele and my strat is sulking.
Of course Albert Collins was famous for having the ashtray on his Tele ... of course he played with his fingers so could mute with his fingertips.
