Even for home use, I'd always suggest using a proper isolated power supply set up - yes its more expensive but a good one will get the best from the pedals without injecting noise.
One of the Y splitters came with the CS6, the other is a Mooer brand one off Amazon, as the Truetone ones cost a fortune.
I was always told it was fine to daisy chain analogue, non-time-based effects, which is why I’ve stuck to drives and compressors.
When I said “gone forever” I meant gone from that particular cable so you can no longer power as many pedals from one power outlet - but yeah you can then use that off cut as a lovely separate cable
Overkill? Possibly. Silent and problem free? Yes.
If I get time one day I'll take a look inside the Caline to confirm.
What do they do differently ? It's obviously more expensive to do, else they would all do it.
Just wondering.
Typically done by having a transformer with multiple separate taps, each into its own regulation. It can be done electronically too.
It’s a health risk .
My advice for what it’s worth is buy a decent isolated power supply with the right amount of sockets for your needs.
Dont mess with electrickery.
