Another Kit Klon Pedal Inc A Tool To Put It Together .
Fingers657Fingers657 Frets: 661
edited March 28 in FX
This one is orange over £200 and has really small control knobs Oh and a Valve .
https://youtu.be/tyE391QU2u0?si=-MmLsdQbonuQfl6j
  • SporkySporky Frets: 29784
    Ugh. An adjustable spanner. The savage.
  • impmannimpmann Frets: 12755
    The wrong tool for every job...
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    I'm not sure it's even a step up from using a Leatherman. Or your teeth.
  • Fingers657Fingers657 Frets: 661
    edited March 28
    The JHS NOTAKLON has a similar tool included.
    This one looks simpler and quicker to build if you don’t use the gloop on the JHS.
    But it’s orange and the control knobs are far too small IMO.
    Also not sure about the foam under the Valve melting with heavy use ?
    Also wondering how this sounds compared to a Behringer vintage tube monster VT999 & a VT911 vintage tube overdrive which both have valves for around £60 each new.
  • Mr_ClawMr_Claw Frets: 106
    edited March 28
    Joe Perkins did a vid on it. Tbh I'm not a Klon guy so it's not for me, but sounds good for what it is. Plus the circuit isn't really a Klon anymore given the tube does the clipping rather than diodes, it has different tone control, lacks clean boost, etc.
  • jca74jca74 Frets: 390
    So...it's a pedal they couldn't be bothered finishing the build before shipping it?
    Basically.
  • TJT1979TJT1979 Frets: 200
    If it was a proper kit (ie. a bag of components) I would understand it more. But just screwing it into the enclosure is pretty gimmicky in my opinion.
    I wonder if the valve operates at proper high voltage?
  • KurtisKurtis Frets: 1038
    I suppose some people don't want to get into soldering/painting/drilling but like the idea of building pedals. I think they could come up with something a bit more challenging though.
    Maybe everything socketed so you can fit all the components/wires? Maybe even throw in a few different values to experiment with.
    Yo momma's on the crack rock!
    edited April 4
    I watched Jim Hagerman’s very geeky very interesting video on it earlier.
    https://youtu.be/NsFy3HV8lAI
    I would love to try one but the very small adjustment knobs put off .
    Thanks for that. Reading the comments under the videos, he is asked what voltage the valve I running at. His answer was 15V. My understanding is that anything under the normal 200+V DC means the valve isn't really doing much. I wonder if this is different as he's just boosting into the valve and using it to clip? Not sure...
