Does noone make one of these?
I want to connect 2 slots from a Zuma via a current doubler into my HX Stomp, which needs 2x 2.1mm male connectors at one end into a single right-angled 2.5mm connector at the HX to try and protect the socket. I already have a Voodoo Labs HX doubler but that has straight connector at both ends.
I know I can get separate adapters to do the doubling and then change from 2.1mm to 2.5mm but that just feels a bit messy.
Given how big a hit the HX is on boards I'm just surprised I can't find a single adapter that does this right.
But.. The connectors at the other end are different (the Voodoo Labs current doubler wouldn't fit my Cioks Sol). More like RCA plugs.
https://logsdonaudio.com/cables/strymon-power-supply-and-line-6-pedal-current-doubler-cable
https://www.amazon.com/Gator-Current-Doubler-Adapter-GTR-PWR-2XCURR-L6/dp/B08W8J83P8?th=1
https://www.sweetwater.com/store/detail/GTRPWR2XCURRL6--gator-current-doubler-cable-for-line-6-pedals-24-inches
