Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
I'd write an add-in.
Consider powershell or vbscript, again ChatGPT may help.
Good luck!
The I'd make a workbook with the current code in it, and a button. The button fires the file open dialogue box, then runs the code on whatever is opened.
You can probably get OpenAI etc to write the script for you in a few seconds. As mentioned it may take a couple of iterations but it is generally pretty good if you phrase the description of the requirement accurately.
I suppose you could possibly write something to edit the XML underlying the spreadsheet, but that feels like trying to fix a leaking tap through interpretative dance.
Ive tried ChatGPT for VBA, a D the results were mixed at best. It managed a simple task (is this range within or overlapping this range) but with inelegant code. It's attempt to populate an array from a filtered table was just wrong, and even by the third attempt it was still using an RBAR approach.
This is a relatively simple problem by comparison - the core code is written, it just needs to be pointable at other files.
