https://www.instagram.com/insta.guitarstuff/
If you had the Kahler string lock type that goes between a conventional nut and the E machinehead, I might have been able to help.
All of this means that I think I am going to need an original part - but still no idea of possible sources.
I had a look. I might give it a try, but I suspect that they are for metric threads.
I did find it slightly amusing that a thread about bolts was posted by someone called allen
It would be necessary to obtain the correct R numbered Floyd Rose part to preserve the string path.
The Kahler clamp integrates a string guide into itself, negating any need for a tension bar. A headstock designed for the Kahler clamp might not have space to accommodate the Floyd Rose tension bar.
In fact, this is the bolt I'm after - it's $1 but out of stock on that website. Someone in Europe has them, but they are something like 30 Euros shipping.
https://www.whammyparts.com/make-model/kahler-replacement-parts/locknuts-and-parts/kahler-locknut-clamp-screw-detail
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
https://www.westfieldfasteners.co.uk/UNF.html
I have previous experience of sourcing bolts using measurements so if it's definitely a 10-32 thread then I think I can get something from either westfield or my local place.
Original on left.
Leaving this here for anyone else who does a search.
After a fair bit of trial and error the screws are:
8-32 UNC x 1/4" Socket Button Head Screws (ANSI B18.3) - High Tensile Steel Self Colour
I bought them from GWR Fasteners
https://www.gwr-fasteners.co.uk/8-32-unc-socket-button-head-screws-4157-c.asp
The official ones cost a few pounds/dollars. These are about 10p each.
I’m going to put the word Kahler in this post purely so it comes up directly in a search
