I have a new live duo project doing covers with backing tracks. Due to the venues we’re booked into (restaurants, cocktail bars, generally smaller spaces) the big loud valve amps that I normally use in full bands need to stay at home.
There are so many options for modeller pedals… Iridium, Walrus ACS1, HX Stomp, Boss IR2, Humboldt Simplifier etc etc
My needs:
1. It has to be in a pedal format for practicality
2. I only need good clean tones because…
3. I need to run my regular pedalboard into the modeller so it HAS to take drive and mod pedals well
4. It has to sound good and have a natural feel
If you have any views/recommendations they’d be gratefully received.
The Stomp is also good but takes some dialling in, the Boss is good and simple.
The ACS1 and Simplifier I didnt like the sound of - i've owned the ACS1 and heard pedals into the simplifier and its not as good at the Stomp or the aforementioned "better" options.
Personally i went with a stomp so i can use it as a multi FX with my usual setup going into an amp or switch in a well dialled amp+cab block for direct gigs or home practice.
PA Hire and Event Management
The music would be a blend of modern female pop (Swift, Lipa, Cyrus etc) and some 80s/90s tunes which need drive tones and modulations (Purple Rain, Oasis, Belinda Carlisle(!!)) etc.
Great wee pedal
Also doubles up great as a "I don't want to buy that pedal but I need it for one song" swiss army knife - there's a reason it's on so many pro boards in the sideman and high end functions scene
Superb and simple in every way.
Are these not a bit fiddly to use in a live situation?
Bandcamp
If you really can get by with a single channel clean solution and won't want to tweak it or change it during performance, then I'd suggest the Simplifier MK II. You can get a nice Fender-ish clean and it takes pedals like the clean pedal platform analogue amp that it is. The cab sim is absolutely fine.
The natural clean and twin clean channels on the Boss IR-2 are good, and it's dead easy to use, but I didn't have great success with mild overdrive pedals in front. Heavy distortion was fine.
I didn't like the ACS-1 or the Iridium. I don't like Line 6 amps, either. The Boss clean models on the GT1000 are very nice but, again, harder to get it to take pedals like a real amp.
I've settled on a Tonex. For an analogue bigot like me, that's a big leap of faith, but it's sounding good and feels good. Also taking pedals well if you set it up to avoid input clipping of the AD convertor.
A lunchbox head really isn’t that much of a pain to carry than a large pedal amp sim.
Feels and sounds way closer to what I’m used to.
I take it to every gig as a backup for my main amp and use it for some festivals/ and rehearsals.Its about the size of a 1.5 Boss 500 series. The point being it works perfectly as a main amp, and is small enough to be a backup,.
Of the pedals, the IR2 was the nicest I had although did have to find a couple of IR's that worked with it.
https://www.instagram.com/insta.guitarstuff/
