And a revelation, you may have noticed the power transformer was giving me much stress and headaches (all my own doing) because its a dedicated 240v that Modulus have made for the amp(and the tweed deluxe etc).
As the cable colours didn't match up with any of the instructions (some of them anyway) I got myself in a right state stressing about it. If only there was somewhere with a written list of the colours and what they are (such as brown/blue 240v, red HV6.3 etc etc), a quick google and a link to the bloody transformer on the Modulus web page and there it was. face palm for me and some relief, if only i'd thought of that earlier, spev11=dull as a brush
Anyway , off to do some work, might solder some more later.
Respect for taking it on - I have the desire but not the courage.
little bit more wiring done today, all the board to socket wiring is done, I've tested continuity on all the connections so far and its all good. Upper wiring next then the heater wiring. I'm still stressed out about the transformer wiring (I know what the black wire coming out from the secondary side between the twin red and twin yellow is but I'm just not convinced I'm gonna put it in the right place).
I really should have gone for a simpler kit but money is tight and I reckon I can only afford to do this once under current circumstances (and I certainly can't afford a new Princeton)
Not as much progress as I'd have liked since the last update, I've finished thea heater wiring (almost, got the two leads from the lamp to the first of the 6v6's to go as well), capcan is wired up and the pots are also now attached. Continuity check passed (at least it shows the wiring is complete so far anyway). Couple of wires for the rectifier and the 6v6's to go on (and some resistors).
I've not done any of the suggested mods yet, will get it working as standard and see how it goes.
Michael has been brilliant with advice and checking stuff over, the kit is brilliant (so much so that i've started saving for the next project for the end of the year)
I will add this, despite enjoying myself thoroughly so far the bloody twisted heater wiring did try my patience somewhat, I'm sure there is a proper way to do it but I haven't found it so it was just get it done
yours is looking good, all the stress will be worth it when you finally fire it up!
it’s great fun amongst the stress, only trouble is wanting to build another
also I’m having a cabinet dilemma, I’ve got enough pine to build either a 1x12 or go for a head as originally planned. If i go for the 1x12 I was thinking of making a Velcro grill on a frame and then a quick release baffle for the speaker so I can try out any of the four I have here ( a 1x12 greenback, 1x10 vt jr, orange 1x12 something and a 70/80 1x10) or just set up a cab to do the same.
Total respect to you for taking on the challenge. It's a great buzz (
(After years of deliberating I finally dared myself to take on a build last summer, but wouldn't have done so without excellently detailed instructions - too chicken to do what you're doing!).
kn
Knocked up a quick and dirty amp stand when i had a quiet five minutes this morning in work. Finished the wiring this afternoon, added the grid stop and the screen, decided not to fit the adjustable bias yet (if at all).
then the nerve racking (that's an understatement) first power on, as you might be able to see the power lamp lit, left in on for 5-10 mins and no smoke. I've got the power up instructions from stewmacs build manual so i'm following that.
Like a dick I didn't bring the tubes so I could only check voltage on the V1 12ax7 pins 9 to 4/5 which shows 6.8v 9stewmac say between 5-7v so i'm reasonable happy)
i'll check all the caps are drained next and home for more startup procedure.
Looking forward to hearing how you get on with the final stages.
hopefully adding valves doesnt descend into chaos
Eqd Speaker Cranker clone
