FS: Wez Venables Zemaitis Inspired "wood top"
I built this to test out the functionality of a laser cutter I purchased earlier last year. Not only was it used for making templates, it also cut all the maple parts from the same piece of wood
Obviously heavily inspired by Zemaitis without being a direct clone
Full build thread of the journey here
https://www.thefretboard.co.uk/discussion/248019/wezv-building-an-electric-with-the-laser-cutter#latest![](https://i.imgur.com/KS5cb0n.jpg)
Spec:
Bosse Cedar chambered body with Inlaid and engraved maple top
2-Piece reclaimed mahogany neck with indian rosewood fretboard
24 fret 24.5" scale, slotted to the rule of 18.
Gotoh HAP Magnum lock tuners
Gotoh Bridge and tailpiece
Handwound P90's made by me(8k alnico 3 bridge with brass baseplate, 7.8k alnico 2 neck with nickel silver baseplate. 52/50mm spacing) including matched wooden pickup covers
Nitro lacquer finish, some checking is starting to appear.
8lb 3oz
The combination of shorter scale with low headstock and neck angles makes it very easy on the fingers
![](https://i.imgur.com/p6WGeFS.jpg)
![](https://i.imgur.com/cvvsMJK.jpg)
![](https://i.imgur.com/wueJatL.jpg)
![](https://i.imgur.com/Q3YsNSC.jpg)
![](https://i.imgur.com/VB4wZ21.jpg)
![](https://i.imgur.com/anqXFiV.jpg)
![](https://i.imgur.com/7ss0ICk.jpg)
I still need to source a case for it, but if one isn't required it is available now for collection
£1250
Instagram
Sadly impending retirement and consequent budget constraints say no…
Instagram
Instagram
